12 bolt (truck rear end) questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2009, 09:41 PM
It's all in the reflexes
Hello I'm new here and had a tech question. I have a 73 GMC 1/2 ton truck with a 355 (400 horsepower) and a turbo 350 with a 2600 stall. It has a 12 bolt 8.875 rear end. I'm not sure of the gear ratio but I know it doesn't have posi. Are these rear ends as good or better than a cars? And what would be the best rear end gears to put in it? Thanks alot
Old 02-11-2009, 03:48 AM
It's a good rear end. If you're sure it's not posi, here's how to find the ratio:
Block a front wheel so it won't roll. Put the transmission in neutral. Jack up one of the back wheels, not both, just one. Sit where you can see the rear U-joint and reach the valve stem of the raised wheel at the same time. Put the valve stem at the 6:00 position. Slowly turn the wheel TWO full turns while counting the revolutions of the U-joint. If it turns over 2-3/4 times, it's a 2.73 or 2.76 ratio, or something real close. If it turns a little over 3 turns, it's 3.08 or 3.07. 3-3/4 turns = 3.73, etc., etc., etc.
Old 02-11-2009, 03:47 PM
Yea my grandpa told me to do that so I should...Whats the difference between a 3 carrier and a 4 carrier?
Old 02-11-2009, 05:14 PM
Different carriers ... carry a different range of gear ratios.
This is a series 3 carrier ...
The area where the gear attaches is thicker on a different series
Old 02-11-2009, 06:52 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
They are a touch weaker than car 12-bolts, but not much. The pinion input shaft is the same size as an 8.5" 10-bolt, but its rarely what breaks.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
12 bolt posi rear end fluid 1972bigblockchev Transmission - Rearend 3 06-19-2007 09:46 AM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
12 bolt rear end question Roy_67_SS350 Transmission - Rearend 3 01-04-2004 06:12 AM
Question about 12 bolt rear end Roy_67_SS350 Transmission - Rearend 6 12-14-2003 11:57 AM
