12 second Malibu's??. - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-20-2013, 10:19 PM
vinniekq2's Avatar
slick size
Originally Posted by gearheadslife View Post
I don't think you'll get 29.5 slicks under it.. not without some fender/tub
work..
maybe some 10.5/26
better off with 9x28.5 than 26 anything.
the guy building this car will likely fit big tires in there. The gear ratio will need to be adjusted to w/e tire fits in there.
with less than 28 inch tire then 4.56 gears
  #32 (permalink)
Old 05-20-2013, 10:37 PM
Banned
iirc he wanted to keep the stock frame rails, so unless he wants the 70's funnycar look/rake
295/50/15's fit tight.. and they are 10x26
28 or taller will take getting out the plasma and redo the tubs..
8" rims are about it on 15" some have got 9" under there with 17-18"
remember we are talking a car that had 195/75/14s as the stockers
  #33 (permalink)
Old 05-20-2013, 11:09 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Frame Notching
Was thinking a 28".
  #34 (permalink)
Old 05-20-2013, 11:16 PM
Banned
Originally Posted by 1Gary View Post
Frame Notching
Was thinking a 28".
thtat work.. then why not 30"
  #35 (permalink)
Old 05-20-2013, 11:27 PM
1Gary's Avatar
The way I am thinking is these cars are known for hooking and the chance of too big tire advertizing effecting the 60'.
  #36 (permalink)
Old 05-21-2013, 06:55 AM
Banned
balancing act, if you want lower rpm to have less season breakage..
  #37 (permalink)
Old 05-21-2013, 08:11 AM
1Gary's Avatar
Polishing a Set of Sneakers by Patrick Budd
  #38 (permalink)
Old 05-22-2013, 07:02 PM
vinniekq2's Avatar
any decisions yet?
  #39 (permalink)
Old 05-23-2013, 05:07 AM
1Gary's Avatar
Still toying with some numbers.Any car is going to be a frame off ground build-up.A glide is going to be used with a 28" tire.A 9" with two center different ratios,one for the 1/8 and the other for the 1/4.Full glass treatment,doors,front end,trunk,bumpers and full Lexan as well.Body stripped to the bare bones.
Adjustable coil-overs for all fours with rear shock mount reinforced.
Costs factor of the LSx being as much or more than a BBC I think has excluded those from the running.Toss up between a SBC and a BBC still needing to run some numbers.Leaning towards a BBC with torque being a factor,but still not happy with the extra wt factor and costs of aluminum heads.Have to see what I can come up with for deals for heads from contacts.Going to talk it over with Pat Mccarthy performance to see what he has hanging around the shop.
  #40 (permalink)
Old 05-23-2013, 01:57 PM
Banned
let me get this,
you are going to spend 3k+ in fiberglass and lexan
but the extra 1000.oo for the lsx is out.??
  #41 (permalink)
Old 05-23-2013, 05:02 PM
1Gary's Avatar
It's alot more than a grand for a LSx.
  #42 (permalink)
Old 05-23-2013, 05:50 PM
Banned
not really, part for part, as seen as you'll be going used parts..
  #43 (permalink)
Old 05-23-2013, 08:14 PM
1Gary's Avatar
The needed electronics pushes beyond the costs of a BBC.
  #44 (permalink)
Old 05-24-2013, 04:18 AM
Banned
850 or better d/p unless you already have it is 600+new and used good one 2-3 bills
msII is 230.00 and the donor ls would have everything else..
I love bbc but money to build isn't any real difference..
now not knowing the first thing about tuning efi (like me) then I can see it. as it be all new, and the only reason a 6.2ltr is sitting waiting to go in the SS ,is I'm clueless on the efi end..
  #45 (permalink)
Old 05-24-2013, 06:26 AM
1Gary's Avatar
Without a cam but buying heads a easy 7 to 8 grand
http://www.summitracing.com/parts/edl-35293
Malibu mack194 Introduce Yourself 1 04-04-2010 03:32 PM
My new Malibu 78 Malibu Hotrodding Basics 2 08-04-2007 12:04 PM
malibu ZZ kendric1971 Introduce Yourself 1 06-26-2006 08:29 PM
69 malibu arahey Introduce Yourself 4 02-01-2005 06:31 AM
non a/c 78 malibu 6speedwagon General Rodding Tech 2 10-30-2003 12:48 AM
