-   -   12 second Malibu's??. (http://www.hotrodders.com/forum/12-second-malibus-232919.html)
1Gary 05-15-2013 10:39 PM
The good about OEM'ed framed/uncut floor boards trailered drag race only two door Malibu's and the bad.Comments encouraged.
vinniekq2 05-16-2013 06:30 AM
I dont understand the question?
what kind of Malibu,and,,,,,,?
gearheadslife 05-16-2013 07:37 AM
What, 12's is cake in a stock g body frame/floors
kso 05-16-2013 09:10 AM
Kinda like asking, in a world where things go from one to ten "what's the advantages/disadvantages of the number five?" :D
Between the choices of low-cost, low-speed and subtlety...and high-cost, high-speed and outrageousness...where is your particular comfort zone? Hey, I know a guy who had that 12-sec Malibu, then cut it up to make it run 8's but there it sits. It was faster when it was stock than sitting now in the garage waiting for some $2,000 engine part.
1Gary 05-16-2013 09:29 AM
I kind lightening the car,a combo that I'm not buzzing to the moon for reliability and less maintenance issues,being in the top(low ET wise)dominating the class.Say target for a number like 12.10 with a car that could run like 11.80.
I come from yrs in 9.90 cars and a partnership of yrs and the most current car is in a RED with a driver that best was 4.56@150mph in a 1/8.Just want to compete in a slower class having fun.
gearheadslife 05-16-2013 03:41 PM
so whats the ?
you know how to build an engine, low12's high 11's are not hard on that plateform thats basicly unchanged for 30 years..
g bodys are not heavy.. my SS is 3300lb and it's loaded..
a stripped malbu should be 3100 or less..
I'd think a low rpm(relative) n/a 355 or a s/c 355/383 would be able to go the whole season with nothing more than valve springs..
or, cheat and build a rock solid lower end and spray your way to glory..
the leak link is the upper link crossmember,
1Gary 05-16-2013 04:56 PM
Well the question is mainly about the car/frame/suspension.Of course I need to decide if it going to be a BBC,LSX,or SBC.................
I want to start collecting parts.Saw some V6 front non A/C springs listed in Craigslist for $50 for the pair.
gearheadslife 05-16-2013 05:23 PM
reinforce the rear link crossmember,
adjustable upper arms
maybe add lenth to the lower links mounts to change the mounting points,
guessing you'll have a cage or at least a 10pnt roll bar..
if not,cage, add boxing members to the frame ends, as both ends of frame are open and not connected to each other..
add g/p body braces,
you want nose up, so sbc or lsx
motor plates will help frame strenth..
some have added a crossmember where the frame kicks up in front of rear tire..
box the center unless running a roll bar/cage
cal1320 05-16-2013 07:28 PM
I had a '78 with a mild 460 BBC. Comp cam 292H, Edel RPM, 9.5 compression, 781 oval ports (2.065 intake), 6 point roll bar, 3.89 gears, Mc Creary DOT tires. Car ran 12.0's easily. Wouldn't 60' with those tires to save its life, but ran 116 mph out the back. These cars need to be stiffened up (a 6 point roll bar wont do it). After every pass I had to tuck the rubber filler strip back under the front bumper.
BTW, 2 door Malibu is hard to come by around here. The 83/84 2 door Olds make a nice looking drag car too.
1Gary 05-16-2013 07:53 PM
Wouldn't the Olds be a heavier car??.
gearheadslife 05-16-2013 07:56 PM
samecar......
1Gary 05-16-2013 10:03 PM
Think I'll stick to a 2 dr 79 to 82 Malibu.
Did search for curb wts.I know it isn't accurate,but it gives me a feel for it.
Malibu: 3254
Cutlass: 3263
Regal: 3600
gearheadslife 05-17-2013 05:23 AM
Malibu: 3254
Cutlass: 3263
Regal: 3600
they are all the same car... the only one thats a tad heavier is the g/p as it has extra bracing..
my monte SS on the NHRA scales was 3350 with a 3/4 full tank
and it's loaded..
I highly doubt a regal has an extra 250lb of sound deadner..
and that half vynil roof isn't that much lb's
finding a 78-82 malbu good luck
finding a 78-88 cutlass much easier..
same with the regal
the g/p and g.n. have more body mounts.. most have them there but no rubber mount in place..
unless you are stuck on the look of the malbu.. no need to pay the extra the chevy will comand because it's a 2door malbu
1Gary 05-17-2013 01:19 PM
Well I am learning from you.It just seems like the Cutlass and Regals are a bigger car.Longer that is.
gearheadslife 05-17-2013 01:51 PM
malb is 193"
cutlass is 199"(83 up) with that just being the difference of the malbu flat grill and tail over the cutlass angled grill and angled tail lights..
malbu 3362 lb (5.0v8 auto)
cutlass 3397lb 5.0v8 auto)
at 30 lb's difference, I'd call that moot..
as the 83 up cutlass areo is better..
and fyi the 78-81 cutlass is the same length and weight as the 78-81 2 door malbu..
