12 volt conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2005, 05:44 PM
12 volt conversion
I`m trying to rewire a 8n ford tractor from a 6 volt system to a 12 volt system.I don't know how to rewire it back with a one wire alternator.Can you get me a wiring diagram for it to change it over to a 12 volt, one wire system? Thanks, Joe Lazenby
Old 09-25-2005, 06:02 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
THe 8N Ford tractor had a positive ground 6 volt system. Changing it to 12 volts you need to change your coil to a 12 volt you need to disconnect your amp guage because you use a voltage guage with an alternator. Put your 12 volt battery in and run the negative cable to ground. Then run your positive cable to your starter solinoid. then run one wire from your one wire alternator to the positive battery terminal. Change all your light bulbs over to 12 volts. The six volt starter will do fine on 12 volts as long as you don't stay on it a lot. If you have to stay on it a lot to start your tractor then you need a tune-up. This should have really been placed in the electrical forum and it would get more attention. Place your questions in the proper forums and you will stand a better chance of getting answers.
Old 09-25-2005, 08:35 PM
poncho62's Avatar
Wiki Edits: 5
moving to electrical...........
6 volt to 12 volt headlight coversion jbrady Electrical 4 03-28-2005 10:35 AM
9 volt to a 12 volt dist 65Guera Engine 7 08-25-2004 03:33 PM
6volt to 12 volt mrjagman Electrical 1 07-21-2004 09:45 AM
6 volt / 12 volt coil question BillyJoe Electrical 3 01-21-2004 05:38 PM
how do i use the 6 volt gauges on a 12 volt system cardsrusa Electrical 6 07-27-2003 03:12 PM
