12 volt conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2006, 01:09 PM
12 volt conversion
I want to convert a 1948 Chevy pickup from 6 volt to 12 volt. I know about changing the bulbs etc. but I would like some input regarding the generator and voltage regulator. Do I find 1955-1957 (Chevy went 12 volt in 1955) parts (can I assume they bolt right in and use same electrical connections?)or do I convert to an alternator and if so details of how to do that and what parts need to be used. Thanks!
Old 09-20-2006, 02:11 PM
Wiki Edits: 31
how about convert to an alternator, using brackets that www.chevsofthe40s.com sells as well as other places, and use a GM 1 wire alternator, and a 5/8" pully to hook it in to the system.
Old 09-20-2006, 04:01 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
First you may want to check these guy's out..
http://www.gener-nator.com/index.htm
They make an alternator that looks and mounts identical to your generator now..you may want to go that way to retain the "Retro look"..
If you go alternator, on a bare bones, go a GM SI series 3 wire internally regulated altenator...and connect it this way:
Of course , you'll have to fabricate mounts..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
'55 T-Bird 12 volt conversion Sidn Electrical 4 08-29-2006 09:03 AM
6 volt to 12 conversion ed keeley Electrical 1 03-19-2006 03:24 AM
6 volt to 12 volt conversion? ajcedar Electrical 7 03-09-2006 06:16 PM
50 Ford 6 to 12 volt conversion JBGTO Electrical 2 02-17-2006 07:19 AM
12 volt conversion joellaz Electrical 2 09-25-2005 07:35 PM
