-   -   12554290 heads on a gen 1 SBC? (http://www.hotrodders.com/forum/12554290-heads-gen-1-sbc-230465.html)
inbredjedd 03-08-2013 08:45 PM
I am picking up a set of 12554290 heads from a 1994-96 LT1. Will I have any issues with these going on a gen 1 010 type block? Are these a good choice? I'm getting them dirt cheap. Is the reverse cooling thing an issue?
ap72 03-08-2013 09:11 PM
Yep cooling issues. Google it
inbredjedd 03-08-2013 09:15 PM
I did in fact there I found quite a bit about it on this site. I did search before posting this but must have did something wrong. Searched again and found all I needed and then some.
BOBCRMAN@aol.com 03-08-2013 09:16 PM
WILL NOT WORK thats why those heads are dirt cheap. Require a reverse flow block with extra water passages in front of block.
ap72 03-09-2013 07:58 AM
It can work but needs machining, vortecs are likely a better option or even better Chinese heAds and the of course better aftermarket heads.
