12554290 heads on a gen 1 SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2013, 08:45 PM
I am picking up a set of 12554290 heads from a 1994-96 LT1. Will I have any issues with these going on a gen 1 010 type block? Are these a good choice? I'm getting them dirt cheap. Is the reverse cooling thing an issue?
Old 03-08-2013, 09:11 PM
Banned
Yep cooling issues. Google it
Old 03-08-2013, 09:15 PM
I did in fact there I found quite a bit about it on this site. I did search before posting this but must have did something wrong. Searched again and found all I needed and then some.
Old 03-08-2013, 09:16 PM
BOBCRMAN@aol.com's Avatar
WILL NOT WORK thats why those heads are dirt cheap. Require a reverse flow block with extra water passages in front of block.
Old 03-09-2013, 07:58 AM
Banned
It can work but needs machining, vortecs are likely a better option or even better Chinese heAds and the of course better aftermarket heads.
Gen-I SBC upgrade from '882 heads to '062 L-31 Vortecs redbeast1 Engine 1 03-29-2010 05:23 PM
Sbc Gen 1, to Gen II exhaust manifold swap? Jimmy Clarke Engine 4 11-22-2007 07:25 AM
Vortec heads on Gen 1 SBC, what else is hidden? Warrant Engine 5 11-12-2006 02:16 PM
How does a Gen III SBC oiling system differ from Gen I/II systems? 70bird Engine 1 04-09-2006 02:13 PM
