$129 HF Planishing Hammer Review - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-13-2014, 05:05 PM
cboy's Avatar
Last journal entry: Finished
Originally Posted by Nonhog View Post
... I want to know if you still get use from this tool or if its a dust collector.
At the moment I am not using it, but that has nothing to do with the usefulness of the tool. Since writing my review we moved from WI to CA and I have not started any new car bodies or metal working projects since finishing the sedan delivery. I would still say, for the beginner or the hobbyist, this is a decent tool for the money.
Always learning...and sharing what I've learned.
The Following User Says Thank You to cboy For This Useful Post:
Nonhog (08-13-2014)
  #17 (permalink)
Old 08-13-2014, 07:45 PM
Wiki Edits: 27
Hf planishing hammer
My son has put a lot of hours on the one in the shop, the dies are now a little rough from some metal sclupture he was doing, I need to spin them in the lathe then re- harden them with some casenite, heres a pict of him working on the Lakester bucket. A 2 X 6 hung from the chain hoist on the gantry crane, some old weight lifting irons on one end to balance it.
cboy , the southworth 4 X 4 lift table is in the left side of the pict and a vise is in the corner slide in. IT retracts into a iron frame sunk into the floor. when it is down the top is level with the floor. the planishing hammer has a steel plate bolted to the base and a 1 " solid bar that fits in the slide - ins.
The Following 3 Users Say Thank You to timothale For This Useful Post:
Chris Kemp (08-19-2014), Nonhog (08-13-2014), tech69 (08-22-2014)
  #18 (permalink)
Old 08-13-2014, 08:08 PM
I love that! Now that is true hot rodding enginuity.
John
  #19 (permalink)
Old 08-22-2014, 03:37 PM
Yea, smarter than the average bear
Great idea
Thanks
  #20 (permalink)
Old 12-19-2014, 02:07 PM
put up or shut up
dusting off this thread cause I'm wondering if anyone has found any sources for different shaped anvils that fit the HF P Hammer? I will look and post any info I find but just wonder if someone out there knows of any that will work with it.
  #21 (permalink)
Old 12-19-2014, 02:16 PM
This might be helpful.
Planishing Hammer Dies Adapters
HEATNBEAT on the metal working forums use to make a stretching die.
I think he will again when the time is right. Pretty cool deal. Too bad he is out.
  #22 (permalink)
Old 12-19-2014, 02:28 PM
put up or shut up
thanks for that. What are CP dies? I don't think Chicago Pneumatic makes them.
  #23 (permalink)
Old 12-19-2014, 04:19 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I just use a shaft that fits the tool and make a head for it and weld it on the shaft... Works fine so far..
Sam
  #24 (permalink)
Old 12-19-2014, 04:23 PM
Use to. Hoosier might (can) ? make them.
  #25 (permalink)
Old 12-19-2014, 07:17 PM
Wiki Edits: 27
beading dies
A few years ago I took the panel fab class, at UVU, they have a street rod, series of classes, I was over 65 and the "grandpa" cost was only $ 100 per semester, The regular students had to pay over $1100. They had a commercial planishing hammer, I don't know the brand, and an assortment of dies. You can do the beading and flanging with the right dies. The lower beading die has a tab welded to it that was held so it wouldn't rotate with a hose clamp. I used it a couple times when the pullmax was booked up . I have started building a smaller "pulmax" type machine out of a heavy cast iron frame from a carton stapling machine, you should be able to copy most of the pullmax type dies.
  #26 (permalink)
Old 12-20-2014, 09:01 AM
put up or shut up
yes, they do some amazing things. I can totally see the point in stopping it from spinning. Thanks for all the advice guys. Once I'm done with my current project my in-between project will be to get my garage up to par, including the p hammer anvils.
  #27 (permalink)
Old 12-20-2014, 10:18 AM
1971BB427's Avatar
I'm glad this thread was brought back into the rotation, as I missed it previously! That's a clever trick with the HF hammer hanging from an engine hoist to work as a portable planisher! Since I do very little of this type of work, I think this little HF tool would be a good addition when I get my shop built.
  #28 (permalink)
Old 12-20-2014, 07:42 PM
Wiki Edits: 27
tin man utube
Kent White has a series of Youtube videos on using the planishing hammer, using different forming dies.
https://search.yahoo.com/search;_ylt...0hammer%20dies
  #29 (permalink)
Old 12-21-2014, 08:11 AM
Wiki Edits: 27
building your own dies
From the UK
https://www.youtube.com/watch?v=cGaaqxUbXv4
I see that he has a lower height adjuster, would work a lot better than the Harbor freight 3 position clicker.
I bought a couple sissor jacks for a buck apiece to use the Acme thread and nut.
ther have been a lot of posts about reworking the HF bead roller but nothing on the planishing hammer other than cBoys repairs, I had to do the same thing to mine after a couple days.
Hammer and Dolly tool review MARTINSR Body - Exterior 12 10-20-2005 05:33 AM
Calling Randy Ferguson, I have a planishing hammer question. MARTINSR Body - Exterior 2 01-28-2005 11:40 PM
air powered planishing hammer 30 Ford coupe Hotrodders' Lounge 0 11-01-2002 01:49 PM
