12s or 13s - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2004, 02:35 PM
12s or 13s
what are the best heads,cam and intake to use to make a truck run 12S 78 chevy long bed 340 gears 350 tranny 2500 stall stock new bottom end. some one told be to use stock heads because they are good for torqu because that is what makes you go. i have 882 heads 750 holley and crane 274 cam but i want more power. it is not going to driven every day. thanks for all your help guys. i think the set up i have will run low 14s but no sure. truck weight is 3700
Old 09-07-2004, 02:41 PM
Siggy_Freud's Avatar
Going to have a hard time running those numbers with 3.40 gears.
You need to run it at the track so you can get a timeslip that will tell you all the information. 60 ft. time, 1/8th mile, 1/4 mile etc. It will have information that will help you determine where you need to boost your performance. Most engines can benefit from aftermarket heads and/or aftermarket modifications to your stock heads. You'd be hard up to find a set of stock heads that cannot be improved upon.
With a fullsize long bed truck, even once you get enough power to run those numbers you are going to have some traction issues that will have to be dealt with.
I dont see 12's without a load of money into the engine, tranny, and suspension and possibly a N02 setup to help you obtain these numbers.
Bringing history and technology together.
Old 09-07-2004, 02:46 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
You're too kind siggy.
78, you've been asking the same questions for 500 posts, over and over and over again. If you're ever going to actually earn a few bucks, buy some parts and build something, let us know. Otherwise, do us all a favor.
K
Old 09-07-2004, 03:06 PM
stepside454's Avatar
what Killer said, Ive responded to this guys questions soooo many times.
Old 09-07-2004, 03:09 PM
Ah. I was unaware lol. I apologize for feeding the trolls.
