12v/24v electrical stuff - wish Doc were here - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-05-2010, 03:59 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Holy schnykies...
Tons of battery tech here:
http://www.windsun.com/Batteries/Battery_FAQ.htm
  #17 (permalink)
Old 11-06-2010, 01:22 PM
ogre's Avatar
the 'Duracell Project'
curtis
i revisted adantessr's drawing and had to add 1 more solenoid
this uses a 3 position toggle switch on/off/on
one on is for trolling
off is isolation
the other on is for charging with the alternator
except for the main battery, you could hook everything up with #10 wire
i would still use heavy duty golf cart solenoids off ebay
this guy has 4 of them for $60
you could use a manual switch but then you probably have more in parts and no electrical interlock.
it wouldn't hurt to put a couple of 30 amp fuses to protect your wires either
  #18 (permalink)
Old 11-07-2010, 07:58 PM
curtis73's Avatar
Wiki Edits: 16
Wow... Awesome. I'm going to print and study that. Is it OK if I PM you later with a question or two?
  #19 (permalink)
Old 11-08-2010, 08:36 AM
curtis73's Avatar
Wiki Edits: 16
Ooohh... I just had a killer idea.
I think I might eliminate the 3-position switch and instead ground Sol 1-3 with an oil pressure switch and make Sol 4 a normally closed. That way, key off makes it 24v without using juice to hold a solenoid, key on disconnects sol 4 making it 12v, and once it gets oil pressure 1-3 energize for charging.
Sound right?
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 08:27 PM
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 06:46 PM
Cam lube gray-graphite stuff vs. the red stuff. 78 monte Engine 28 01-23-2003 11:24 PM
Cleaning electrical contacts Kevin45 Electrical 0 01-05-2003 10:22 AM
