12v - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2004, 05:18 PM
jwart's Avatar
12v
hey guys picked up 65 c10 v8 & 3 wire alt. dropped in hei dist ran for couple mins won't start no mo'. traced low voltage to dist 7-8v, fuse block 3-4v. primary wire from bat to volt reg. & horn relay still hooked up get 3-4v, been along time but isn't that wire resistor wire across rad. support. should i just run new wire to fuse box bypass reg & horn relay( with alt system) with 10ga. for primary feed? thanks jw
Old 04-08-2004, 06:37 PM
poncho62's Avatar
Wiki Edits: 5
You could, but make sure that it will shut off with the key. If the 12 volt sourse is on the charging side of the circuit, it won't shut off.
If you can find the resister wire, just strip it back about a foot or so, and you should have 12 volts.
Ontario Rodders
Old 04-09-2004, 10:40 PM
old fart
Last journal entry: "touch of grey"
HEI distributor
As mentioned, the HEI has to have a full 12 volt switched power source. Tap it right from the ignition switch.
