12v air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2010, 08:19 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
12v air compressor
Hey all, I'm looking for input and recommendations for 12 volt compressors. It will be for occasional use for a 3-5 gal tank to blow an air horn...harbor crap good enough?..... thanks
Old 10-09-2010, 12:24 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I just installed a Viair 325c for an air operated door system for a Bricklin.
It gets a workout but fills the tanks fast. I'm guessing about 6 gallons total tank capacity.
Found good prices with accessories and many choices of different compressors at www.hornblasters.com
vicrod
Old 10-17-2010, 07:30 AM
deadbodyman's Avatar
Wiki Edits: 11
Those 12v Hf compressors should work fine for air horns...I doubt they would last very long but at twenty bucks there cheap enough to replace every once and a while...I was going to buy two to hook up to my air bag system,they're suppose to pump up to 160 lbs...We'll see.
They might even have the whole air horn system, just use the horns you want..
Old 10-18-2010, 12:30 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Junkyard - Lincoln or Cadillac air suspension compressors work well and are high pressure too. I have 2 wired in together to double the volume. Use 10 gauge wire with a couple of aligator clips to hook up to the battery. I have another hard wired in my RV with a Freightliner air tank mounted on the frame to have constant air pressure on the road.
Old 10-23-2010, 06:42 AM
Hwyhogg's Avatar
Thanks for the responses...all good I like the idea of the junk yard...though lately, those guys think everything is gold ...that's a whole 'nother rant...I did make a couple of horns using the plans I got off ebay. Go to youtube and type in "pvc train horns". The guys name on there is dozerboymiller. I made a couple, and they really are loud...even with just blowing by mouth. I will have to post a video up of mine soon.
Thanks again,
James
Old 10-23-2010, 06:52 AM
Wiki Edits: 11
OH THOSE..Carefull hwy you'll give some old guy a heart attack...
Old 10-23-2010, 07:08 AM
Wiki Edits: 11
http://www.streetfire.net/video/trai...unny_26323.htm
Old 02-20-2012, 09:50 PM
New Member
Thanks for this informative post. 12 Volt Air Compressor has hundreds of applications and can be very useful in many situations for hobby, semi-professional or professional use like as spraying, nailing, inflating, dusting, cleaning, etc.
Old 02-23-2012, 11:47 AM
dinger's Avatar
That was some funny sh....stuff! I wonder if anyone has shot at them..lmao!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 03-01-2012, 04:30 AM
New Member
12v air compressors*are an essential item for any recreational, farm or work vehicle. Thanks!
Air Compressor Review/Suggestions hoffmandirt Garage - Tools 16 03-13-2012 01:24 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
New Air Compressor blsnelling Garage - Tools 58 10-18-2007 09:36 PM
my first air compressor Guitar4God Garage - Tools 16 09-28-2007 07:14 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
