12V Electric Fan Setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2012, 09:20 AM
64Joker's Avatar
64Joker
What amp power toggle switch do I need to use between my toggle switch and my ign/acc 20 amp fuse box connection?
The relay is setup with a 30 amp, but I presume my toggle switch would have to be a 20 amp back to the ing/acc fuse box!
See Attachment for configuration.
Name:	Spal Fan Wiring.jpg
Old 09-14-2012, 10:41 AM
ogre's Avatar
the 'Duracell Project'
the load on the switch is only the relay coil
less than 1 amp
any switch will work though i would add a 1 amp fuse in the line
personally i wouldn't use a switch as the only means of turning on a fan
add a thermal switch in the circuit
to toggle the fan off and on when the thermal switch calls for it
Old 09-14-2012, 11:32 AM
64Joker's Avatar
64Joker
Ogre
Thanks! Yea, this is a temp setup and I do intend to add a temperature sensor to the configuration (eliminating the toggle as suggested).
So the 1 amp in-line fuse you recommend would go between the toggle switch and the ing/acc fuse box connection, right?
electric fan setup Camaro820 Hotrodding Basics 11 05-24-2012 07:30 AM
Electric Fan Setup zildjian4life218 Engine 5 04-22-2011 08:33 PM
Electric Cooling Fan control setup 76_TA Engine 11 09-01-2010 07:13 PM
Electric Dual Fan Setup stfinney Engine 23 05-25-2008 11:15 PM
SBC electric fan setup... Sagacious Engine 5 08-11-2004 06:29 AM
