12v source for custom gauge cluster - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 11:50 AM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
I'm installing a custom vdo gauge cluster in my 57 Chevy truck project. I have two options for a 12v source. The vdo instructions call for a straight 12v source for the instrument lights and I have one in my custom wiring harness but I'm wondering if it would be better to use the instrument light source on my headlight switch so that i can dim the lights? Any thoughts?
murray
Old 01-28-2007, 01:07 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You will need (2) 12 volt sources for the guages.
One is for "ignition ON" to provide continuous power to the guages.
The other is for the dimming feature of the guage lighting. This is derived from the headlight switch.
vicrod
Old 01-28-2007, 02:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You SHOULD Be able to pick up Instrument Dimmer from the Instrument lighting on the radio circuit..
In most cases on a modern CD player, (with Auto Dimmer) this wire isn't even used on the radio..
If you use a straight unswitched 12 volt source, the panel lamps will be on 24/7/365, giving you dead battery's..
If you use a switched source, it will be on whenever the key is on..not really needed during the daylight hours..
If you Tap into the radio dimmer, it will dim and only be on during darkness or when the headlamps are on. Be sure to UPGRADE The dimmer fuse at the fuse buss to support the added draw of the panel lamps if needed.
Doc
gauge cluster conversion? 91_Silver Interior 0 04-12-2006 09:30 PM
Analog to digital gauge cluster akattp Interior 8 11-05-2004 03:42 PM
El Camino gauge cluster swap? BT74 Interior 1 02-06-2004 08:49 AM
Monte gauge cluster madhat Interior 1 09-27-2003 08:25 PM
box located on back of gauge cluster spankthru Electrical 10 06-16-2003 10:18 AM
