Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 13.1 compression Chev 355?
Old 02-07-2013, 06:01 PM
bygddy bygddy is offline
Originally Posted by Shawnb View Post
Is there a way thru compression testing I can calculate the the actual compression ratio? I dont have a true build sheet. I have a word document typed by the owner outlining the items in the motor. Im sure it makes no reference to the decking of the heads if any. Like I said the plan would be to go to Edelbrock heads anyways. Not if my only option would be 110 gas. I live in a large metro area (Minneaplois) so E85 is everywhere but I dont want to regulate my trips around town based on where I can buy 110. If E85 is not an option, which I hear mixed reviews about, and I would need to change pistons and heads then its not worth doing anything to it. Id sell it and build another. ??????
If u have a document, then what's a pn# for the pistons? If u cant find it, bare minum pull a valve cover and get a casting number, if your looking at buying heads anyways, screw it, pull a head and see what you have.
