Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 13.1 compression Chev 355?
  #18 (permalink)
Old 02-07-2013, 10:44 PM
Shawnb Shawnb is offline
I will pull the vc as soon as possible. I was attempting to do this research now because this may influence what project I do next.
This is what the sheet says....355 Chevy. Steel crank. 6" Eagle H beam rods. 13:1 Wiesco pistons. Victor jr intake. Bow tie cast iron heads 64cc 2.02 I 1.60 e. Jr motor sports cam int duration @.050 .256. Exh duration .050 .264. Gross lift int 546, exh .565. Duration int .294, exh .300. Lash hot .026. Lobe center 105. Rpm range 3000-7200. Roller rockers. 1.6 ratio. 4 bolt main out of 1980 truck.
It included everything. Carb (don't have more details at this time. Holly 800?), dist, whole ignition. Deep oil pan. Flywheel. Starter. Everything. It was running on an engine stand when I bought it. Started right up every time. Idled nice. No abnormal sounds. No smoke out of headers. Revs up smooth. Sounded awesome.
I posted pics of the motor on the prior page on this post.
Questions are this: are these good heads? Is this a good set up? What would you think something like this is worth? I think they spent quite a bit on this engine. Any input is welcome..
