Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 13.1 compression Chev 355?
  #25 (permalink)
Old 02-09-2013, 09:32 AM
S10xGN's Avatar
S10xGN S10xGN is offline
Gotta love a turbo!
Hook up a battery and run a compression test. Cranking compression over 215 or so will be hard to get by on pump gas. You can either swap heads or run a cam with more duration or a tighter LSA. Increasing overlap will lower the dynamic compression.
Russ
