13.1 compression Chev 355? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-09-2013, 07:46 PM
F-BIRD'88's Avatar
Yada Yada Yada
Originally Posted by Shawnb View Post
So based on the specs of the engine carb to pan ready to run with all accessories what would you sell it for. Anyone chime in. Im not sure???
thanks in advance.
This not the place to market your engine. take that somewhere else.
You bought it you should have a clue.
It is worth what someone wants to pay you for it.
  #32 (permalink)
Old 02-09-2013, 10:02 PM
Not trying to "market an engine". Marketing it would include including my contact info, which I wont do. Ive never bought or sold a used engine. Im also not familar with GM or high compression race gas engines. I bought it based on the idea I would modify it to run on 93. Based on responses from people like yourself it sounds like its not a good idea to take it apart. Thats why Ive used this forum for advise from others with more experience like every other person who has posted a question looking for help here. Chill out.
  #33 (permalink)
Old 02-13-2013, 02:16 PM
Choctaw Bob's Avatar
Sounds like you already buy race gas by the drum. What's one more? Me, I hate to admit I've made a serious uncorrectable blunder. Now, with that said, it doesn't sound like you have the skills or the inclination to fix this problem yourself. If you did, you would pull it apart on the stand where it sits and see what you got. Most folks I know would never buy a used race engine from anything less than a reputable engine builder. So...that leaves you with the option of breaking it down and selling for salvage the parts you don't use. Use the block, the rods and crank and buy new parts that fit what you intend to do with the car. 500 HP on pump gas is not difficult with a 355 if you use a set of AFR or comprable heads and a hydraulic roller cam. It's at the upper range of what you can expect without power adders.
Maybe the guy you bought it from will buy it back at a discount you can live with.
If you do not want to register, fill this field only and the name will be used as user name for your post.
how much CR with AL Heads, 355 chev, and 91 octane bigalow Engine 11 11-02-2011 10:28 AM
355 sbc compression question Tommy Brown Engine 14 04-26-2010 12:05 PM
355 flat top chev 47fordnash Engine 6 04-16-2010 01:25 PM
compression question for 355 Mike_82 Engine 2 12-25-2005 02:23 PM
350 Chev Compression ? 1941chev Engine 8 09-21-2003 01:25 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
