2 things.
the 13 vane rotor is unneeded, a 10 vane is fine. next; you can use a hose clamp and a soda pop can metal to collaspe the 1 piece sealing rings. be carefull & lube them up. wrap the soda can metal around the rings, 2 at a time is fine. use the clamp to compress them for several minutes
At the Bonneville Salt Flats, first gear is known as 130 mph. |
The 13 vane pump was developed to handle the needs of the EC3 converter control system on 4L60E transmissions and is not needed on a 700. On top of that you WILL need the 13 vane pump housing and stator for the correct hydraulics; that will not work in a 700.
Replace the rings on the input shaft. They seperate the various oil circuits and will crossleak after overhaul if they aren't new. Why take a chance on clutch or gear train failure??? Get someone to install new rings AND size them. |
