14 bolt 3.375" 4 link brackets - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 09:46 PM
Where can I find the brackets to mount a 4 link to the GM FF 14 bolt axle with a OD 3 3/8"? I only seem to find them for 3" axles...
Greg
Old 02-17-2011, 09:57 PM
ericnova72's Avatar
More for Less Racer
As far as I know, you won't find any. I did a rear with 3-1/4" tubes, I took the 4 brackets and bolted them together in a stack and chucked the whole stack into the lathe and bored the brackets out to the bigger size. It was the easiest way I could think of to make them all precisely the same. The same thing could also be done on a Bridgeport mill with a boring head also.
The instructions(Competition Engineering IIRC) said to use a die grinder to enlarge the holes if needed, but that seemed pretty imprecise to me.
An alternative would be to find someone in your local area with a PlasmaCam cutting system or a WaterJet cutting machine and have them made to your spec's.
Old 02-17-2011, 10:01 PM
Thanks,
Pardon my language but it appears that "broke dick racing" has em for 3.5"
http://shop.brokedickracing.com/Chro...es_p_9944.html
I dunno if I can get em like that (too big) and just try and get the gap to be the same for both sides?
Greg
Old 02-17-2011, 10:26 PM
OH! I forgot about taking some in (For small templates) and poppin em into the cutting machine but larger. The welding school I went to has one and they like it when people take in stuff for them to do (good learning).
Worst case that's what I'll do.
Good IDEA!
Greg
4-Link Brackets fredbaker Suspension - Brakes - Steering 1 09-05-2009 09:00 PM
neat old early 1960s show car "Missing Link" for sale junkyard junkie Hotrodders' Lounge 0 05-26-2009 06:38 PM
Making "spring steel" brackets/clips? hd_rider General Rodding Tech 13 03-10-2008 07:13 AM
I need the '"Peel and Seal" Home Depot link that someone posted!!! hemi43 Interior 3 03-09-2005 06:48 AM
