14 bolt 30 spline rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 09:54 PM
i want to know how to tell between open or what ever rearend i have pic of mine and need to know if i can use my carrier for a locker
Old 01-29-2011, 09:10 AM
big gear head's Avatar
High Performance Rear Ends
I'm assuming that you have the GM 14 bolt 10.5 rear end with floating axles. This rear end used the standard differential case for the Detroit Locker. You just split the case, remove the axle and pinion gears and put the locker in.
trying to find 8.5 ten bolt 28 spline posi ken konoff Transmission - Rearend 10 01-01-2010 06:28 PM
Change Ford 9" - 28 spline to 31 spline fredbaker Transmission - Rearend 5 09-27-2009 04:12 PM
28 Or 30 spline 10 bolt question hemi joe Transmission - Rearend 8 05-03-2009 12:23 PM
12 bolt truck pinion spline count 85406 Transmission - Rearend 1 07-14-2007 08:15 PM
Chevelle 12 bolt axle spline count JamesRS Transmission - Rearend 4 10-23-2004 10:21 PM
