14 bolt dually vs IH dually rear??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2010, 08:28 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello.
Quick question??
Got a 8 lug, 14 bolt chevy dually rear and a 5 lug, rear outta a 54 International dually 1.5 ton. Heard the IH may be a Dana but not sure. Which one should I use on my new project? Anyone know much bout IH rears??? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 02-01-2010, 08:43 PM
Not sure about the axle in the international, but the 14 bolt full floater is pretty bulletproof, i dont see how you could go wrong with it.
Old 02-01-2010, 08:49 PM
big gear head's Avatar
High Performance Rear Ends
I know that IH used Dana rear ends because I pulled a Dana 60 out of one years ago. If this is a Dana 60 then there will be a 60 cast into the case in one of the gussets on the housng. If it's a 44 or a 70 then these numbers will be cast into the housing in the same place. The Dana rear ends are very popular with after market manufacturers. So is the 10.5 14 bolt GM rear end. It's up to you.
Questions on a GM 14 bolt rear. 1tunda Transmission - Rearend 8 12-26-2008 09:13 PM
How hard is it to swap in a 14 bolt? Ford_Assassin Transmission - Rearend 2 10-23-2008 05:41 PM
Complete rebuild of GM 12 bolt rear, quick questions 406chevelle Transmission - Rearend 8 03-24-2007 02:02 PM
gm 14 bolt disc brake question rock on Suspension - Brakes - Steering 2 01-03-2007 05:16 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
