14014145 relay TCC ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2009, 10:47 AM
fast68's Avatar
likes chevy trucks & boobies
is relay number 14014145 in 1982 for trucks the 700r4 TCC relay ?
just making sure
if so then i need to remove all that from this truck since it has been converted to th350 long ago and since i have tge cab gutted for restoration and paint currently
four pins on the relay
two wires brown and light blue to the brake pedal combo vacuum cruise switch
also in the same relay harness are black, white, and gray wires that run over to the 208 shifter assembly and light
why is this ?
shouldnt the 4x4 light in the dahs only need the switch on the 208 case?
why would it need to be tied to the TCC harness and relay ?
thanks for anything at all
yesterday:
a few years ago:
700r4 tcc lockup theory supercoop Transmission - Rearend 3 02-01-2009 06:16 PM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 04:09 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Omg, Car Fire!! Malibu1980 Electrical 21 06-16-2004 01:34 PM
