1406 edelbrock carb electric chock hook-up - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2004, 06:10 PM
I am installing an edelbrock performer 1406 with electric chock on my 68 327 Camaro. Where do I run the power wire from? Do I run power from the switch side of power for the chock?
Old 09-03-2004, 06:41 PM
MI2600's Avatar
Member# 3287
You can connect to any 12v source that is on when the engine is running. I've heard it 's not a good idea to tap into the key to coil line. In your case, that line is only 6-8v when the engine is running because of the resistor wire.
On my '86 El Camino, I ran from a keyed hot wire located at the oil sending unit.
You'll probably have to tap into a dash accessory or the fuse block.
Good luck.
