1406 edelbrock carb help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 10:51 AM
hddave1's Avatar
im rebuilding 1406 edelbrock carb and i might have run into a problem...i am looking at a exploded view of the 1406 carb and in the print they show a pump discharge weight and a pump discharge ball the kit i bought comes with 2 of these balls but i dont see a pump discharge weight and i didnt see one in the carb when i tore it down...will i need the weight or do i just use 1 check ball or both and not worry about the pump discharge weight...i bought the carb used so im not sure if the carb has been gone through or not but im hopeing im not missing parts...all seems to be there but the weight...looks like the weight is about 3/16 round by maybe 3/8 long..
Old 04-30-2011, 11:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You could try 2-3 balls (extra(s) acting as a weight), or a ball followed by a short piece of brass stock like brazing rod.
Old 04-30-2011, 11:12 AM
hddave1's Avatar
yea never thought about that...theres a mech in town that i called and he said he might have a edelbrock carb parts and may let me have the weight if he has it...we will see i guess...thanks
Old 04-30-2011, 01:19 PM
Irelands child's Avatar
Do you have a copy of this manual ? See pages 32-33
Dave
Old 04-30-2011, 01:44 PM
hddave1's Avatar
well i lucked up and found the weight i needed so im good to go...the carb is a 1406 but im changing parts so it will have the specs of a 1405 carb....thanks guys for the advice
edelbrock 600 cfm (1406) nastypurplenova Hotrodding Basics 26 05-18-2011 08:52 AM
Electric Choke Adjustment on Edelbrock 1406 4-BBL Carb horvath Engine 24 01-11-2011 07:49 PM
Edelbrock 1406 help please tommytempest Engine 13 03-12-2006 09:21 PM
1406 edelbrock carb electric chock hook-up mferris72 Engine 1 09-03-2004 06:41 PM
edelbrock carb 1406 or 1411? MopaRV Engine 7 07-30-2003 01:07 AM
