Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1406 edelbrock problems
Old 05-11-2013, 07:17 AM
Travis P Travis P is offline
Originally Posted by Irelands child View Post
Looks like you picked an ancient thread to post to - but ,,,,
Take your carb off, disassemble the top , clean it out and install a new/better inline filter. When you are done doing all that, check the float level, reinstall, then check the fuel pump pressure. An Edelbrock only needs 4 -4.5 pounds (that's info in their IB which you absolutely need to understand)
thank you for replying i will deff try all that you have mentioned will keep ya posted thanx again
