Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1406 edelbrock problems
Old 05-11-2013, 10:43 AM
Irelands child's Avatar
Irelands child Irelands child is offline
........ and as far as Edelbrock quality on the carbs, I've been using them since they first came out and the only problems I've ever had was dirt once and high pump pressure on a 460 powered pickup truck. These Performer carbs are a mildly updated Cater AFB by and built by Magneti Marelli Powertrain USA - some of which have that or Weber cast on the main body - I have one of each right now. This is the Speedway filter I'm using now:
(both brackets are on the filter now)
Gasoline that had MBTE additive affected any carb that was made out of aluminum, regardless of brand. Luckily we never had it where I live and even better yet, it has been banned as an ecological problem from the rest of the country
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Travis P (05-11-2013)
