Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 14101083 Cylinder Head
Old 01-02-2013, 05:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by ChevroletSS View Post
Whats goin on guys?? Have any of you ever used a chevy head # 14101083?? Im trying to figure out if they are worth using. I have had them sittin in the basement for a while now and if I were to use them it would be on a pretty much stock engine but only if they are worth using. Does anyone know the flow specs on these. Im wanting to know if these could make some decent numbers. There are tons of engine ID sites but I never can find info I need. Any help is much appreciated..
Thanks
GMPP says:
P/n 10125377 SBC Cast Iron L98 Center Bolt Valve Cover Head.
This is a cast iron cylinder head assembly used on 285 hp 350 engine (P/N 12353641). This complete cylinder head assembly includes 1.94” intake valves, 1.50” exhaust valves, valve springs (P/N 3901068) and valve spring caps (P/N 14003978).
Technical Notes: This cylinder head has 64cc chambers. The cast number for this head is 14101083 or 14096217. This cylinder head has 1987 and later inlet manifold bolt pattern. The center two bolts are at a 72° angle.
