Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 14101083 Cylinder Head
  #19 (permalink)
Old 01-05-2013, 06:11 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Tip: a rat tail file helps you straighten up the corners
A hand flat metal file helps you keep the walls straight and smooth your carbide progress.
if you stick to it and do a good job those heads will turn out very well.
Just pretend they are camel back heads.
