Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 14101083 Cylinder Head
  #56 (permalink)
Old 01-24-2013, 12:45 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Turn the head over and work on the roof of the intake port. Get a long 6" shaft carbide burr cutter so it will reach all the way to the bowl from the intake side.
using a 3/8" cylinder shaped cutter with 6" shaft:
Raise the roof of the port approx 1/8th inch from bowl to exit and carve the flow path on the common wall side of the bowl while streamlining the guide boss. Use a felpro 1205 gasket as a guide. Never mind the BS on the floor of the port for now.
Look at the pic I posted.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
ChevroletSS (01-25-2013)
