None of this general porting on this stock SBC head requires a flow bench. You got to put some air in a tire first before messing with the tire gauge.
A picture says a 1000 words. http://www.hotrodders.com/forum/atta...0&d=1347916622 i did not do this head. Buts a really good pic of the desired finished form. Look at the chamber too. Last edited by F-BIRD'88; 01-26-2013 at 02:45 PM. |
| The Following User Says Thank You to F-BIRD'88 For This Useful Post: | ||
ChevroletSS (01-28-2013) | ||
Thanks for the info. Greatly appreciate it. Can you point me in the right direction on some bits to use for porting. All I have is the port and polish kit from jegs which is ok but not efficient. I need something about six inches long id say and one maybe three inches long. A good carbide bit I guess. What do you suggest
![]() Now that just doesn't make any sense.
| The Following User Says Thank You to 1Gary For This Useful Post: | ||
vinniekq2 (01-29-2013) | ||
The whole purpose of marketing and advertising is to separate you from your money in exchange
for what ever is being offered by the advertiser. And convince you that you need it. And they will go to what ever lengths thats nessessary to "tell you what you want to hear", to get the sale. |
We all know as casted OEM heads are all the same.Right??. I'm call it BS. So to follow the same pattern reaps the same results without a flow bench to check if your just hacking away at a pc of metal or really doing better or worst. Taking tech back to what amounts to caveman times is illogical.
The first set of heads done right usually the response is OH!!!. That's what I have been missing.......... |
Hey F-Bird check out these bits. will these work ok. They are similar to what you have below.
I guess these are made for cast iron??? I have no idea. http://www.goodson.com/5_Pc_Set_of_L..._Rotary_Files/ |
You can use a coarse aluminum bit on iron all that will happen is a rougher surface finish from some chatter the wider flutes create, but they'll cut just fine. Aluminum will gum up the smoother fine iron flute almost instantly. You can kind of get away with the fine flute on aluminum if you frequently run the bit into a piece of bar bath soap. This lubricates the flutes preventing the aluminum from sticking. Same thing if you're cutting aluminum with a rotary stone or drum sander, run the stone or drum sander into piece of bar soap every few cuts and it'll stay pretty clean of imbedded aluminum. This of course leaves your bits and stones smelling clean and refreshing. Bogie |
Goodson is nice stuff.
you only really need two of them with a long 6" shaft for this SBC head porting job. LFR-34C and LFR-46C Yes these Double cut style are for cast iron. Not good on alumunum. Use single cut for aluminum. There are other sources that are a little less pricey. But avoid cheap chinese junk. Welding supply and industrial tool supply stores usually have all this stuff. google search carbide burr The same onces but with a 3/8" cutting head diameter are about half the price. I use the various shaped mounted stones to shape the short side radius. The amount of material that needs to be removed is not that much to shape the short side. radius. You don't need to run these at 10,000 rpm. Ebay: remember good quality tools are not sold for dirt cheap. Can be real hit and miss. Last edited by F-BIRD'88; 01-30-2013 at 11:47 AM. |
| Cylinder head ID? Anyone know what a head with a 5x stamp? | bigtmoney | Engine | 3 | 02-11-2012 03:49 PM |
| cylinder head hp | 81Blue | Engine | 9 | 11-14-2004 03:32 PM |
| More cylinder head | HemmiGremmie | Engine | 2 | 02-29-2004 12:11 PM |
| cylinder head help | Lightspeed | Engine | 5 | 06-14-2003 01:54 PM |
| Cylinder head help | 80Camino | Engine | 2 | 10-21-2002 04:45 PM |
