Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 144 blower on 350
Old 01-03-2013, 07:01 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by swanson1930 View Post
wanting to add a b&m 144 blower and was wondering how much of a HP gain will I have
Traditionally, the gain is on the order of 25-40% over naturally-aspirated with a modest 5-6 lb boost.
300 times 1.25 = 375
300 times 1.4 = 420
To use 8 lbs on pump gas, you'll need a 8.0:1 or less static compression ratio.
To use 7 lbs on pump gas, you'll need a 8.5:1 or less static compression ratio.
To use 6 lbs on pump gas, you'll need a 9.0:1 or less static compression ratio.
To use 5 lbs on pump gas, you'll need a 9.5:1 or less static compression ratio
To use 4 lbs on pump gas, you'll need a 10.0:1 or less static compression ratio.
I would make a phone call to Weiand and find out what their recommendation is for ring end gap and piston to wall clearance.
Look into some kind of ignition retard that changes with boost changes.
