15:1 383 stroker using 70s block
The block is a factory 4 bolt main 1971 casting. It has been shot peened bored and stroked. It has been bored .040 over with je .080 pistons. Eagle alloys 4340 crank and 4340 h beam rods. It has a cloyes timing cover and adjustable timing chain set. There is a comp cam i have the cam card just dont remember the proflie off the top of my head. Comp cams solid roller lifters molly .125 longer push rods. Crane cams gold series roller rockers with 7/16 studs and crane cams glod series stud girtles. Brodix track one heads that have been decked to 52cc and ported and polished. Brodix high rise intake with a race demon 1040 carb.
[QUOTE=cam383aro;1231177]The reason I don't duplicate there motor is because I'm not trying to build the same thign my friend built... Wanna make it my own, if we copied what other people did and don't make our own design we would still be driving model Ts...
This threads old He never built it!!!!This is 2 years old and hes on another thread today asking about his first 383 build How about combining them?PJ - This thread is now split from the original OP's thread he posted in, it's all his now... Last edited by 68NovaSS; 07-09-2012 at 10:03 PM. |
700 hp 383,,,
recipe==simple actually
Contact Scott Shafroff or Jeff Lukovich.Buy their 434 bracket/street motor.Both are honest guys with good products.Engines start at 11k before upgrades.Both these guys offer 850 HP 434s though they would be terrible on the street.Both of these guys offer a 630 ish HP 434 that is better for street use though even they use big solid rollers. If you want specs,I have that too |
The .080 is the dome height on the piston. I responded to the post as I have a 383 that is running 15:1 compression and I read old posts, and figured others do too.
Also, tell us how you get 15:1 compression out of a dome that is .080 inches?? A domed piston that has a .100 inch dome is only -0.50 cc in volume. In a 383 motor that calculates out to 9.73 with 76 cc heads, and 11.07 with 64 cc's.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association Last edited by 68NovaSS; 07-09-2012 at 09:57 PM. |
BTW, some compression ratio calculators (and catalog info/advertisers) use a negative number for a dome (i.e. "-5cc"), others use a positive number. Be sure to check the calculator and the advertised figures to be sure they're not 'backwards'. |
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
| Tags |
| 383, chevy |
| 383 stroker kits?? for a 98 block | kennyhammond | Engine | 7 | 01-18-2011 02:08 PM |
| knocking sound in botom of the block in a 383 stroker | 1971gmc383 | Engine | 1 | 01-07-2010 04:35 AM |
| 383 chevy small block stroker | ZAPP59 | Engine | 4 | 02-24-2006 09:36 AM |
| 383 stroker block and cam ???????? | mupton | Engine | 1 | 01-26-2006 09:50 PM |
| yeah they take a 350 block and get it ready for a 383 stroker kit | 79 cutlass | Engine | 6 | 01-06-2004 05:53 PM |
