15 or 20 amp circuit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 06:58 PM
In my garage I have a circuit composed of 12 gauge 20 amp wire, but has 8 15 amp outlets.
Is this a 15 or 20 amp circuit?
Old 04-05-2011, 07:07 PM
ogre's Avatar
the 'Duracell Project'
12 ga wire = 20 amp circuit.
Old 04-05-2011, 07:27 PM
Wiki Edits: 27
elect code
It's been a while , but the code allowed 15 amp rated outlets for residential use on a 20 amp 12 ga wire circuit. If I remember right commercial 20 amp outlets have a t shaped slot for the "hot" side. It's been a while since the Elect code class but if i remember right the outlets should have the wires fastened with wire nuts or connectors approved for 20 amps, and a pigtail wire to the 15 amp outlet. the 15 amp outlets are not rated for passing thru 20 amps. I think an elect buildin inspector has to be sharp to catch that when the building permit is signed off. building codes are a guide line that the JHA (jusisdiction having authority ) can adopt or modify for local conditions.
Old 04-05-2011, 07:49 PM
302 Z28's Avatar
If I am reading you right you have 8 15 amp receptacles fed from one #12 wire. If that is what you have then the total load of all receptacles cannot exceed 20 amps. Additionally no individual receptacle cannot exceed it's rated 15 amp capacity.
How is the #12 wire protected? Is it fed from a 20 circuit breaker?
Vince
Old 04-05-2011, 07:58 PM
Wiki Edits: 27
20 amp
If you plan on using a high current draw appliance-machine you could change an outlet to a commercial 20 amp outlet. the engine heater I need to start the diesel navistar came with a 15 amp cord, I have had to replace it twice in 10 years.
Old 04-05-2011, 09:15 PM
20 amp circuit breaker
The number 12 wire on this circuit is protected with a 20 amp circuit breaker
Add-on cornering lamp circuit??? jimfulco Electrical 10 05-26-2011 08:09 PM
200 4R/700 R4 Lock Up Circuit Ted's37 Transmission - Rearend 0 08-12-2009 08:26 PM
circuit board trouble american muscle rulz Electrical 2 06-24-2007 11:17 AM
GM Wiper Circuit Elder Rodder Electrical 17 08-18-2006 07:45 AM
window circuit i3igmind Electrical 1 11-17-2003 11:57 AM
