Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 15 gal air compressor for priming engine bay
Old 03-27-2013, 10:50 PM
Serkan Serkan is offline
I am new to the forums. I read some articles and threads here and I am amazed with the information provided.
I have been reading for hours. Thanks everyone for sharing their knowledge.
I have a project car that I am working in my small garage. I am redoing the engine bay. I stripped it to bare metal replaced some panels, new wheel tubs, lots of welding etc.
Can I spray Epoxy primer, 2k high build primer and sealer with a 15 gallon air compressor ?
It says 5hp , 6cfm at 90psi on the compressor but I think those numbers are inflated.
I was thinking it is possible since the engine bay is fairly smaller surface than the exterior panels. And I can do it in sections.
My real concern is not to get water vapor in the gun. Any recommendations to prevent that ? Draining the tank, adding oil/water separator.
Would it help to let the air compressor cool down after it is filled ?
Any recommendations are appreciated.
