Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 15 gal air compressor for priming engine bay
  #25 (permalink)
Old 04-25-2013, 03:47 PM
oldred oldred is offline
Originally Posted by Serkan View Post
What about running a 50' hose and roll some of it inside a large garbage bin filled with cold water and put a water separator after that ?
That works like a charm, a barrel filled with water with a coil of Copper pipe in it is the usual way to do this and it's probably the best way short of a refrigerated drier to accomplish the condensation process. I think that while a length of rubber hose would not work quite as well as Copper pipe I seriously doubt you would be able to see the difference. If the air is cold and dry you might want to just try running the hose off the tank first because there might not be enough moisture in the air to be a problem.
