15 gal air compressor for priming engine bay - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-30-2013, 10:36 PM
When I was a kid I watched my dad paint a tractor with a undersized air compressor. He would spray a few passes, then drink a beer while waiting for the compressor to pump up, paint job didn’t come out too good….
  #17 (permalink)
Old 03-30-2013, 10:47 PM
Faith - Respect - Trust
Another thought would be hook the two compressors up in tandem, that way you would be getting the value of the CFM output from both compressors and the added 25 gallons won't hurt. I don't know the CFM output from the compressor that has the 25 gallon capacity but often a larger tank means they put a bigger compressor head on it. Your still in the over use mode but, if they where working together your recovery time would be much better.
Make sure you rough up the metal on the new pieces you put in with something like 80 grit paper on a DA...that way you'l get much better mechanical adhesion.
The installation of the new parts looks quite well done...good job.
Now if I had know it wasn't an American muscle car well...it wouldn't have mattered...LOL
Ray
  #18 (permalink)
Old 03-30-2013, 10:52 PM
LOL...I bet your Dad came our real good...I remember back in the day when I used to indulge in a few pops while painting in my hobby shop...on cool days my flash times where measured by 2 beer...instead of 1. I hated those transparent colors that took 6 ot 7 coats...I'd run out of beer before clearing the car and had to resort to the old fashioned way to check to see if it was ready for another coat by touching the masking paper to see if it was flashed...LOL
Ray
  #19 (permalink)
Old 04-24-2013, 07:29 PM
OK so I went to a tool rental place and I have 2 options :
-18 cfm at 90 psi , 10 gallon air compressor (gas powered)
-125 cfm, big tank (diesel powered)
Big compressor is more expensive and not convenient for me.
How would a compressor with high cfm, low capacity tank do for painting car ?
The compressor is smtg like this :
  #20 (permalink)
Old 04-25-2013, 11:22 AM
Anyone ...?
  #21 (permalink)
Old 04-25-2013, 11:30 AM
Should work ok, 18 CFM should keep up and in any case the recharge time for that outfit would be seconds anyway. Make sure the exhaust is outside the building however for safety reasons (carbon monoxide) and the fact that the gasoline engine could be expelling soot and possibly even oil that could play havoc with your paint.
  #22 (permalink)
Old 04-25-2013, 11:34 AM
I understand that it will supply enough air for the gun to spray continuously but doesn't it have to run all the time and cause a lot of condensation in the line ?
Is there an easy way to check if the air compressor is letting oil in the line ?
  #23 (permalink)
Old 04-25-2013, 02:12 PM
That compressor is going to have a 100% duty cycle and it's meant to pretty much run continuously however it will get hot enough to keep the water in vapor form with very little condensing in those small tanks. The solution is something that should be utilized anyway regardless of the compressor and that means cooling the air so the water can condense and be removed before reaching the spray gun. There are several methods for doing this but the most popular is not going to be practical for a temporary setup, that would be 50' or more of metal piping with collection drops and a water separator. In your case you are going to have to improvise by doing things such as choosing a day to spray with relatively low humidity and maybe running the air through a cooler of some type before passing through a water separator as near as possible to the gun. What you need to do is cool the air as much as you can by whatever means you might have available so that the water will be in liquid form rather than a vapor as it enters the moisture separator, a desiccant filter may be all you would need depending on the amount of moisture in the air, obviously a cool dry day would be far less of a problem than a hot muggy day. Even with a big high volume compressor there is no safe way of just connecting a hose to the compressor and connecting the gun to the other end, it's successfully done all the time but it depends on several factors and it's always risky. The only safe way of avoiding water is to have proper cooling and separation methods in addition to whichever air supply you have.
BTW, I don't think I would attempt to do this with that big diesel jack hammer compressor!
  #24 (permalink)
Old 04-25-2013, 02:58 PM
It is still not warm in Canada and I can definitely pick a low humid day to do the job.
What about running a 50' hose and roll some of it inside a large garbage bin filled with cold water and put a water separator after that ?
  #25 (permalink)
Old 04-25-2013, 03:47 PM
That works like a charm, a barrel filled with water with a coil of Copper pipe in it is the usual way to do this and it's probably the best way short of a refrigerated drier to accomplish the condensation process. I think that while a length of rubber hose would not work quite as well as Copper pipe I seriously doubt you would be able to see the difference. If the air is cold and dry you might want to just try running the hose off the tank first because there might not be enough moisture in the air to be a problem.
Anybody own or have info for a 5hp 18.5 80gallon blue Excel Compressor air compressor snapped finger Garage - Tools 0 03-24-2013 11:33 PM
questions about 80 gal 5hp ingersoll rand industrial compressor richie ross Garage - Tools 9 03-22-2010 08:43 AM
Air compressor off auto engine? Ernesto Engine 3 10-30-2009 10:29 AM
5 gal of pig crap = 5 gal of gas cboy Hotrodders' Lounge 9 10-12-2006 11:11 AM
Air compressor from car engine? cboy Garage - Tools 54 04-04-2006 08:59 AM
