15 in tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 10:32 AM
15 in tires
We have a 95 chev van. 15 in tires are getting hard to find. what can I use instead of 15,s. does chevy have a rim that is the 5-53/4 pattern but a larger tire size or do I go aftermarket? Also what size should I go to 16 17 or 18. THANKS
Old 04-15-2013, 11:14 AM
Jimbo17's Avatar
Nostalgic Racing Decals
Same problem here
I have a 1986 Chevy van and I just went through the exact same problem you are having.
The tires I purchased are Nexen Roadian HT P235/75R15 I think I paid around $400.00 for 4 of them.
I have had them on the van now for about 6 months and I like them and have had no problems at all.
I am hoping someone else will answer this post that might have other idea's on how to solve the problem.
The tire place where I purchased these tires also told me that within a few years I will not be able to find 15" tires any longer.
Jimbo
Old 04-15-2013, 11:34 AM
Faith - Respect - Trust
How times change...it used to be you had 2 options for rims and tires on mid and full sized vehicles, 14 inch and 15 inch. Now it's anywhere from 16 inch and up. Thank goodness for Companies like "Cocker Tire", making all kinds of tires for the restoration side of the automotive hobby. Who ever thought that 14's and 15's would be hard to find.
Ray
Old 04-15-2013, 11:42 AM
if you beat my boat, well race
oah contraire!
15" tires are readily avaliable!
the trick is.... do not buy them from a tire shop, they are more orentied on this newer crap!
i order all my tires online.
benifits of having a set of "coats 1000's" in the garage
further more, re measure your lug pattern.
those years its more than likely 5 on 5" bolt circle for the 1/2 ton stuff.
8 lug for 3/4 ton +
5 on 4.75 bolt circle for the small chevy stuf
Old 04-15-2013, 12:03 PM
Irelands child's Avatar
Good grief - use Tire Rack - here's a link to at least 60 just 235-75x15's : Tire Search Results and are a common p/u or van size
Irelands child
Old 04-15-2013, 12:09 PM
sedanbob's Avatar
B F Goodrich Radial T/As are available in a wide variety of sizes for 15" wheels. For folks wanting the 'Big and Littles' look on their rod, but want the same tread pattern, they are very handy. X2 on TireRack.
Old 04-15-2013, 01:33 PM
Geeze, even Costco lists ten different types of tires in that size.
Old 04-15-2013, 02:09 PM
Last journal entry: 27
i got mine at walmart...
Old 04-15-2013, 02:49 PM
sedanbob's Avatar
I found my rear tires at Walmart, but they didn't carry the smaller size I wanted up front. But Sams Club (another division of Walmart) carried the smaller size. Go figure.
Old 04-15-2013, 07:02 PM
I change all my own tires, you can save a lot of money if you do it yourself.
I have 3 places I go. Tire rack will even ship them to a installer for you if you want.
discounttiredirect.com
tirerack.com
Ebay.com
Old 04-15-2013, 09:35 PM
vinniekq2's Avatar
I use tireland wholesale as a supplier
Which tires? Bowtie man Hotrodding Basics 3 12-26-2010 10:10 AM
what to use on tires?? yragat Body - Exterior 12 09-09-2008 10:19 PM
Tires, which is LF,LR etc 39chevy Suspension - Brakes - Steering 2 10-08-2006 06:05 PM
tires bill D Introduce Yourself 1 09-02-2006 10:15 PM
tires corenele Transmission - Rearend 0 06-19-2003 12:27 AM
