1500 and 3500 front suspension. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2006, 03:52 AM
1tunda's Avatar
Hi, I am in the process of building a 2wd 94' 1500 Chevy Truck. I have a 8-lug FF 14-bolt rear axle that I will be using. My question is will a rotor or spindle from a 2wd 3500 Chevy truck fit on a 2wd 1500 chevy truck. I want to try and do it this way instead of using wheel adapters to change the lug count.
Mahalo
Kevin
Old 06-11-2006, 09:18 PM
A rotor change would be a LOT better ... If it would work. I doubt it ...
Might need to change the A arms and spindles also ...
Old 06-12-2006, 05:50 AM
astroracer's Avatar
Stop off at a Dealer and ask them to cross-reference the part numbers. That will tell you what will and won't work...
Mark
Question for the dozens of S-10 freaks on the board. willys36@aol.com General Rodding Tech 42 06-17-2005 06:21 PM
Camaro front end welding costs>>> Jackyl Hotrodders' Lounge 6 12-31-2002 07:17 PM
