153 Chevy II 4 cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2011, 11:55 PM
I have purchased a running (60K) Chevy II 4 cylinder motor.
I wish to build a small pick up to drive around in my old age and speed is no longer an issue.
I have just about everything from the flywheel forward and am looking for specs and ideas about transmissions and just generalities of what the actual motor is so I can do repair work and order parts with some common knowledge of what is inside this motor.
Any information will be appreciated and I welcome all comments about this motor.
Thank you in advance for anyone that adds any information (to which I am willing to share) to this request.
Old 09-05-2011, 05:40 AM
willowbilly3's Avatar
Last journal entry: Body mods
It seems like they use 283 pistons
Old 09-05-2011, 06:22 AM
poncho62's Avatar
Wiki Edits: 5
My understanding is that it is basically a 230/250 Chevy six with 2 cylinders cut off and uses a lot of the same parts.......Sounds like a fun engine to play with
Old 09-05-2011, 07:42 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here is a bit of information..You may have lucked into an Iron Duke as there are 2 different 4 cyl GM motors of that era..
http://www.ehow.com/info_7753450_che...fications.html
Sam
Old 09-05-2011, 08:33 AM
If it,s a chevyII engine [153 c.i.] it's NOT an iron duke .!!
Most any Chevy manual trans or auto will bolt up .
dave
Old 09-05-2011, 01:12 PM
The Iron Duke was a series of inline 4 cylinders
Sam
starting in 1977 and most of them were in Pontiacs. This is a 1967 inline 4 cylinder from a postal jeep. It is the same motor that was in the Chevy II Nova from 1962 to 1968 or 69. It is not the Iron Duke motor, but thank you anyway. This is from they gentleman I purchased the motor from.
Old 09-05-2011, 03:35 PM
Wiki Edits: 31
the 151 was increased in displacement to 181 and was used in marine applications for many years. I'm pretty sure the current production marine 3.0L 4cyls are the same 181 ci... Very strong runners.. My dad had a '73 Starcraft Chieftan mark 5 21' cabin cruiser, with the 140hp version. It would run a bit under 55 MPH on plane, and for a boat of it's size with that small of an engine is quite fast... anyway, the common hop- up for the 151 is the marine cylinder head. Should be very economical. IIRC the 151 was primarilly designed to break 30 MPG in a Compact car
Old 09-06-2011, 02:24 PM
4cylinder t5 out of an S10 for a good trans
Old 09-06-2011, 03:03 PM
The 151 is not the same engine, it is not the same as the 181, the 153 was increased to 181 & is still in production for various uses incl. marine .
dave
Old 09-06-2011, 06:22 PM
LATECH's Avatar
X 2 I think it would be a wonderful combination
Old 09-06-2011, 11:39 PM
Here are a few links for you
Chevy 153
GM 4 cylinders 151 153 181
153 4cyl Flywheel
153 Cu In Chevy Distrib
153 ,4cyl. chevy II head question
Chevy II fourbanger modifications
153ci Chevy II engines
Old 09-07-2011, 01:09 PM
One of my friends who is on various forums has a Model A Sedan Delivery with a mercruiser 4banger and a T10. You'll have to do some engineering to get the Hydraulic clutch correct, along with I think a jeep flywheel. Also you may have to have a machine shop shorten the pilot on the input or lengthen the splines on the maindrive (input gear)
Old 09-07-2011, 03:20 PM
I REALLY DON'T UNDERSTAND WHEN IT'S SO SIMPLE TO SET UP MECH. CLUTCH LINKAGE, WHY EVERYONE SEEMS TO WANT TO USE HYD. ..
DAVE
sorry about the caps...
Old 09-08-2011, 12:17 PM
man did I flub that...shows Im human. He has a 'T5' from an 'S-10' not a 't-10'
whoops sorry
The rest of the info contained above is correct
Inline 6 cylinder chevy 194 62Nova194 Transmission - Rearend 4 09-05-2011 08:09 AM
bad cylinder chevy 400 Chevy21 Engine 6 03-24-2007 08:21 PM
chevy 6 cylinder ceaser62 Engine 2 02-23-2007 01:08 PM
Help! 53 chevy master cylinder old car hunter Suspension - Brakes - Steering 2 08-14-2006 08:49 PM
