153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 08:02 AM
I recently swapped out a 6 banger, for a '66 283 in a 55 Chevy, I didn't know that the original 265's with a manual trans came with a 168 tooth flywheel. Anyway we installed a 153 tooth. The starter is an original style which bolts to the the bell housing and we found out yesterday that it won't work, as the starter teeth are about an inch away from the flywheel. So rather than go through the trouble of changing the flywheel, I'd like to know which other starter I could use...for example when going to a parts store for which model and year starter should I ask for. The 283 does have the threaded bolt holes in the block. I tried one starter that I had laying around but no luck. Would appreciate some helpful info. -----Classic Chevy Dave
Old 09-17-2010, 03:06 PM
SSedan64's Avatar
Starter Info >> http://www.chevytech.com/2c42o6.html
Go to >> http://www.rockauto.com/catalog/raframecatalog.php & look up a 70 Corvette then click on the highlighted Part#, it will show other cars that use this Starter.
Old 09-17-2010, 03:44 PM
poncho62's Avatar
Wiki Edits: 5
When I built my 55, I used a truck bell housing that had the mounting for the starter.......I used a block mounted starter....If I remember correctly (this was 35 years ago), I had to cut away part of the bell housing....but it worked
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
383 chevy stick flywheel 65ELCMO Transmission - Rearend 5 03-18-2010 08:23 PM
Flexplate 350 Chevy 153 or 168 tooth? Ghetto Jet Engine 5 05-18-2006 09:45 PM
87 350 one piece seal flywheel 153 or 168 tooth punk1c5040 Engine 4 08-03-2005 10:54 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
