16 inch tire size question??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2009, 01:53 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hey All.
Been a while.
Wanting to know wat some of the taller 16 inch tires you can buy is?? Got a dually rear on my new project and I want tall rear tires. Tnx, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 11-16-2009, 04:10 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
A lot of them came stock with 235/85/16 which is 32 inches tall from the factory, I have a few sets of this size tire and 4 dually rims, eventually these will hopefully fit under my Suburban.
Here's a link to all tires available in 16 inch wheel size from one supplier.
You could also swap out the duals for a wider wheel and go much bigger in tire size. I've seen adapters that go from the 8X6.5-inch lug pattern to the 10X11.25 lug pattern for running semi-truck wheels and tires.
There's an idea, using Super Single semi-truck tires and wheels on a dually truck, HMMM. . . my Suburban isn't finished yet. . .
Old 11-16-2009, 04:15 PM
I run 255/85-16s on my dually. These are BFG Mud Terrain T/As. I get them from Tire Rack. I needed to use a spacer between the rear wheels, as I was getting sidewall wear from rubbing under load.
Brake lights switch oldsmo Electrical 4 10-19-2006 12:23 PM
Camaro Tire Question ugly stupid impotent Hotrodding Basics 5 01-16-2006 05:42 PM
Bore size question 53LEDSLED Engine 5 05-12-2005 07:55 PM
Tire size and posi problems? killerformula Suspension - Brakes - Steering 5 04-12-2004 06:38 PM
37 Ford tire size wally Body - Exterior 2 02-10-2004 05:12 AM
