168 tooth flywheel in 200R4? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2004, 04:47 AM
JG37's Avatar
I'm doing an S10 V-8 conversion and want to use a 200R4. I need the 168 tooth flywheel for the starter to clear the headers. The flywheel clears, but just barely. Can anyone tell me if this is a bad idea? Thanks in advance;
Jerry
Old 04-26-2004, 08:25 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
If the torque converter bolts to the 168 tooth flexplate, then you shouldn't have another worry with this set-up.
Old 04-26-2004, 06:26 PM
JG37's Avatar
Thanks for the reply. I have the torque converter bolted up just fine, and with a minium od shaving, there should be no interference! Itt'l be close, but it won't rub! I really want to run this 4 speed over the 350!
Jerry
Old 04-27-2004, 08:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
You could run a mini starter to gain clearance.
Old 04-28-2004, 04:47 AM
JG37's Avatar
A mini starter sounds like a possible solution. I've never heard of one. Do you know where I can find one?
Thanks
Old 04-28-2004, 07:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
============ www.summitracing.com
www.jegs.com
a couple of places to start ( GRIN ) looking for a mini starter
Old 04-29-2004, 04:40 AM
JG37's Avatar
Thanks......sometimes I'm just not real bright!
