17 spline rear yoke? 55-63 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2007, 05:17 PM
Does anyone have or know Ware to get a 8.2 chevy rear yoke 17 spline. I would like a forged but cant be to picky. 55-63 chevy
Old 10-22-2007, 04:16 PM
" Back in the day "
I broke my share ( and few other folks share too ) of 55 to 64 Chevrolet center sections. They are not much good once you get a big old heavy 55 Chevy into the 13's.
I solved my problem with a 57 Ford 9 inch rear end. It was 2 inches or so narrower that the stock 55 rear end ... stronger and had a way better selection of parts and pieces.
NEW .. 9 inch Ford yokes with the larger 1350 series U-Joints are only 75 dollars. I ran a 28 spline 57 Ford 9 inch under my Big Block 69 Nova ( 4 speed car ) until it ran low 12's ... before I started tearing up stuff. Then the 31 spline axles and center section cured that ...
You need a new driveshaft anyway ... I would go ahead and CURE this issue NOW ...
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
55 chevy bumper bct Body - Exterior 2 01-04-2006 07:15 AM
rear disk brake for newer model chevy truck woodmanscott@hotmail Introduce Yourself 1 12-21-2005 11:53 PM
63 biscayne rear differential problems biscuit63 Transmission - Rearend 8 07-29-2005 04:37 PM
