174 B&M Blower question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2008, 03:13 PM
Just wondering what the most horsepower anyone has seen with one of these on a Big Block Chevy. I am thinking of building another motor and I was curious. Back in 2000 I had a 462 BB with ported Rectangular Port heads, solid cam, 8.24:1. It made 670 horsepower and 646 ft lbs. of torque. Just wondering If I could get 700 Horsepower?
Old 06-11-2008, 03:30 PM
174 Blower Question
I built a small block with a 144 blower and got great results. When you go to more cubic inches you might have to go to a bigger blower, to make it efficient.
Old 06-11-2008, 06:30 PM
I have a friend who is gonna sell me my old one back. He had one on a 427 that ran real strong. The manifold is gasket matched to the LS-7 Heads. Just wondering if anyone has seen dyno numbers more then what I made.
Old 06-11-2008, 07:10 PM
T-bucket23's Avatar
Wiki Edits: 26
My 142 added about 100 HP to a stock crate small block. You may want to spin it a little faster on that big block. Those mini blowers will usually only produce abut 6-8 lbs of boost on a small block with stock pulleys. It is going to be less with those bigger cylinders to fill I would imagine.
Chet
Old 06-13-2008, 03:56 AM
I was reading about Jim Davis being on here. Just wondering what he thinks? What kind of Horsepower is possible?
Old 07-16-2008, 12:34 PM
I am surprised that no one has seen any combos with these.
Old 07-16-2008, 03:43 PM
I think that blower is a little under sized fir the motor. Sure it will bolt up but you would get a lot better performance out of something larger. Even if you spin it faster you'll just create more heat and make it less effiecent. But i do belive you can make 700HP with it if you want. Talk with some one who can grind a custome cam and let them know your combo and im sure they can help you reach your goals.
Old 07-18-2008, 11:16 PM
The big question is which heads are better? Worked oval ports with big valves or rectangular ports? Hearing I should go to a 427 and make a little more boost.
blower idle rpm problem Ratoflic Engine 7 12-01-2008 04:31 AM
Blower gear oil question Arrowhead Engine 4 03-29-2006 10:15 PM
Blower Question? Mightymouse Engine 19 08-24-2004 11:36 PM
quench question for the blower guys minesblown Engine 7 10-16-2003 01:49 AM
Overheating?? & Question on blower ratio? chamz_16_2003 Engine 4 08-27-2002 02:05 PM
