175 lincoln - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2011, 03:08 PM
175 lincoln
I have a 175 lincoln mig 220 volt I'm having trouble with the gas when I first hit trigger you can hear the gas but if you hold the trigger on it quits flowing??? any ideas on what to and how to check it with out putting it in the shop??? Ihad trouble with it not feeding wire a few weekks ago took the handle apart and turn little brass contact around and it worked fine till today any help appreciated. oh if I let off the trigger and wait a second then you hear gas again for a second then nothing
Old 03-28-2011, 04:41 PM
figured it out the tube that goes from solinode thru welder had rubbed a hole in it replaced it everything good now
Hot Rod Lincoln 2BADMK8 Hotrodders' Lounge 8 09-02-2008 04:37 PM
Lincoln Pro-Mig 180 lt1_performance Garage - Tools 4 05-10-2008 11:10 PM
'52-54 lincoln 2dr ht sprecher48 Hotrodders' Lounge 0 04-09-2008 02:27 PM
400 to 429 in 79 lincoln DusterNut Engine 4 11-25-2003 09:57 PM
Hot rod lincoln Bruce Knobel Engine 9 09-10-2002 12:35 PM
