-   -   18 12/2 flex fan shroud clearance question (http://www.hotrodders.com/forum/18-12-2-flex-fan-shroud-clearance-question-46850.html)
Jag Daddy 09-01-2004 03:43 PM
I picked up a 18.5 inch flex fan which is 1/2 inch bigger than the 18 inch clutch fan I run now. How much clearance do I need between the shroud and the edge of the fan? Also is there a way to adapt the clutch fan to the clutch? Do you think the extra 1/2 inch is going to give me any more air draw?
Regards
Mark:thumbup:
