18+ Volts! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2009, 09:12 PM
454headache's Avatar
18+ Volts!
I took out the old alternator on my '90 454 C1500 truck, as it wasn't working. Put the new 100 amp one in. I was happy as could be seeing the voltmeter read 14 instead of 11 and below for a change. Went for a drive, and the voltmeter started climbing, sometimes to 18+, and it would never drop below 16, even at idle. I barely got the truck home. I was thinking that this might be due to a bad voltage regulator, but it seems that they are inside the brand new alternator, so that worries me. I'm picking up a new regulator tomorrow, but if its not the problem then what? The battery is also new btw.
Old 08-06-2009, 09:18 PM
302 Z28's Avatar
Only thing it could be.
Vince
Old 08-06-2009, 09:37 PM
Alright, I'll pickup a new one tomorrow. Hope it solves the issue.
Old 08-06-2009, 10:39 PM
When installing the alternator, I didn't unhook the battery (yes yes I know). And I accidentally shorted the alternator batter terminal to my valve cover which caused sparks. Could this have damaged the regulator?
Old 08-07-2009, 06:43 AM
302 Z28's Avatar
Yep.
Vince
Old 08-07-2009, 03:07 PM
Got a new alternator, no more problems. Lesson learned, always disconnect the battery.
Need some volts! Everett II Electrical 7 08-03-2008 06:34 PM
starter solenoid shorting ignition junkyardjeff Electrical 5 03-24-2007 05:15 PM
Brake lights switch oldsmo Electrical 4 10-19-2006 12:23 PM
i have 2 volts with the key off Waksabi Electrical 10 06-30-2006 07:11 PM
18 volts drill machines godfrey Garage - Tools 6 11-11-2005 02:58 AM
