Yes the 3 inch will flow better but the extra length (32 inch versus 18 inch) will cancel out a lot of the flow improvement gained from the extra diameter.
3" pipe has 180% more cross section than a 2-1/4 pipe but 32 inches just happens to be 180% longer than 18 inches. So there should be no flow difference between a 32 inch long, 3 inch diameter hornie and a 18 inch long, 2-1/4 diameter hornie. |
15" of water refers to how they measure the vacuum. It's a vacuum that's strong enough to lift water 15" up a tube. Imagine putting a 6-foot clear rigid plastic tube on a vacuum cleaner and sticking the tube straight down into a bucket of water while the thing's running. If it sucks the water up 15" higher than the level of water in the bucket, that's the strength of vacuum they used. The "Hg refers to how far it'll suck mercury up a tube. The whole stinkin thing's kinda confusing, like measuring power in horsepower vs kilowatts.
Conversion: 1.5"Hg = 20.4"H2O = 0.74psi But just in case anybody's curious, glasspacks actually are quite a bit quieter under water, with sort of a burbling sound. Can't say how they performed though, what with the wet tires and the resistance caused by water up to the stinkin doors, but the sound was kinda cool. |
........that I'm going to cutapart and make resonators out ofShane |
I have used dynomax bullets as a resonators with great results. They also have perforated tube design and they don't cost much. They flow also like a straight pipe.
Recently I install dual 12" dynomax mufflers in a very ugly sounding exhaust that would resonate so badly you would think the exhaust was dumping in the cab. After the two little dynomax's, it sounded almost like stock exhaust with no flow penalty. |
| Brake lights switch | oldsmo | Electrical | 4 | 10-19-2006 11:23 AM |
| low profile tires for 15 inch Halibrand reps | peranaman | Suspension - Brakes - Steering | 3 | 06-28-2005 04:36 AM |
| Purple Hornies | 79 Malibu327 | Engine | 6 | 02-07-2004 06:00 PM |
| Purple Hornies Glass Packs!!! | fsiramps | Engine | 2 | 10-08-2003 10:40 PM |
