180-degree/flat-plane crankshafts & Engines - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2002, 08:49 PM
Post 180-degree/flat-plane crankshafts & Engines
Does anyone know a source for 180-degree/flat-plane crankshafts and a good reference for building such an engine? Thanks.
Old 06-16-2002, 08:56 PM
4 Jaw Chuck's Avatar
Post
There is no advantage to having a 180 degree crank in a V8 unless you like the motorboat sound. The only advantage is the balancing is simplified so a high rpm motor would have different harmonics. I doubt you need to spin your 350 Chev to 11 000 rpm do you? Why do you need this kind of crank, magazine article?
Outlawed tunes from outlawed pipes
Old 06-16-2002, 09:58 PM
Post
I'll agree and then some. As I undestand it, a flat crank doesn't make more power, costs more and not as easy to set-up. Why then? its all about the sound.
